Example Code
Add and rename MS Excel worksheets
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The following code illustrates how to programmatically add and rename several worksheets on an Excel workbook using the NI LabVIEW Report Generation Toolkit for LabVIEW.
Description
The following code illustrates how to programmatically add and rename several worksheets on an Excel workbook using the NI LabVIEW Report Generation Toolkit for LabVIEW. This is useful in situations where more than 4,000 rows or columns need to be attached to the document. If trying to attach more than 4,000 elements, LabVIEW generates error code -41114. Also is useful if you want to programmatically add and rename worksheets for a better distribution as long as data keeps increasing.
Requirements
  • LabVIEW 2012 (or compatible)
  • NI LabVIEW Report Generation Toolkit
  1. Download the attachments that fits your LabVIEW version.
  2. Write a File Name and a Worksheet Index Name.
  3. Run the VI
  4. Click on the Generate Data button. Each time you click it, 3 colums with 4,000 rows will be created and attached to File.
  5. Stop the VI.
  6. Open the file that will be saved (if prompted to) on your Desktop.
VI Block Diagram
Francisco S.
Account Manager
www.ni.com/soporte
Comments
sdgsdg
Member
Member
on
Is it already exsisted in Labview Generate Report Pallet?
