Example Code
Add Two Waveforms That Start at Different Times using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI returns the superposition of two waveforms.
Description
Use this VI to add one waveform to another. The augend input is the base waveform to which the addend is added. Therefore, the augend should have a starting time earlier than the addend. The waveforms do not need to be the same length. However, they must have the same dt. The augend time index is the point on the augend upon which the addend should start adding to.
Requirements
Software:
  1. LabVIEW 2014 (or compatible)
  1. Supplying this code as a subVI, or by copying the block diagram.
VI Snippet
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
