Example Code
Add Titles to Rows in a Spreadsheet Array
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to add row or column headers to a table and save the result to a ASCII file
Description
2D arrays in LabVIEW are organized that the first dimension resembles the rows and the second dimension resembles the columns of a table.
To add headers to every column you only have to add a row on top of the table, since the row is the first dimension you only have to use the 'Build Array' function.
In case you want to add a header to every row in a table, you first have to transpose the table with the 'Transpose 2D array' function (so rows and columns are switched) and then use the 'Build Array' function and the transpose the table again to reverse the first transpose operation.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. (Optional) Change the data for the column headers and the numeric array as well as the path
  2. Select the mode to add the header either to the columns or the rows
  3. Run the VI
Add headers to row or column of a 2D array LV2012 NIVerified.vi - Front Panel.png
Add headers to row or column of a 2D array LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Jared S.
Applications Engineering
