Because the call executable step does not use a module, the executable time is not displayed by default in the test report. This example shows how to include the EXE execution time information for any Call Executable steps in a report.
Because the call executable step does not use a code module to call the EXE, TestStand will not include the module execution time information for any Call Executable steps in a report. However, the results for the step do include a TotalTime property, which you can use to generate a ModuleTime property which will be included by the report generator.
In order to access the result data for the step before it is added to the resultList, you can use the SequenceFilePostResultListEntry callback, which provides the result data in a parameter Parameters.Results. In this callback, you can use the following TestStand API call to generate the ModuleTime property and populate it with the TotalTime value:
Step.Result.SetValNumber("TS.ModuleTime", PropOption_InsertIfMissing, Step.Result.TS.TotalTime)
The report generator will automatically include the ModuleTimne in the report, so no further action is needed
Module Time for Call EXE - TS2012.seq
TestStand 2012 or compatible
Module Time for Call EXE - TS2017.seq
TestStand 2017 or compatible
