Example Code
Adaptive Median Filter Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI removes ‘salt & pepper’ noise in gray scale images.
Description
Here in this VI, every pixel in window is verified whether it’s noisy or noise-free based on min & max gray levels in the window. Finally, noisy pixel is replaced with the median value. A simple filter was developed with 3*3 window, or better result, one can remodel the program by using 5*5, 7*7 window and so on.
It is the program for adaptive median filter whose algorithm is described in "Digital image Processing by Gonzalez" text book.
Requirements
  • LabVIEW 2012 (or compatible)
  • Vision Development Module 2012 (or compatible)
  1. Browse a gray image in the front panel.
  2. Run the VI to remove the ‘salt & pepper’ noise in gray scale image.
VI Snippet
Comments
rom391
Member
Member
on
hello, this program interest me but I have only labview 8.6. So can we save your program for labview 8.6.
navruz_ebru
Member
Member
on
Hi, I also try to add noise and denoise but in my simulation noise and image changes constantly. Also I use your simulation I use only original image and noisy image and delete other parts, your simulation look exactly like mine
