Example Code
ActiveX Interface to LabVIEW Projects with LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This VI demonstrates the ability to access LabVIEW as an ActiveX server.  It allows you to list items in a project and run VIs from within that project.
Description
This code uses activeX calls to programmatically control the LabVIEW environment.  This demonstrates the capability of LabVIEW to be controlled from other environments through activeX calls. This link provides some additional help resources for LabVIEW and ActiveX.
Requirements
Software
LabVIEW 8.6
LabVIEW 2012
  1. Open the project and run Access Project.vi
  2. Choose a project file in the Project Path control
  3. Run the VI and click Load Project.  The list should be loaded with project items*
  4. Select a VI and click Run VI
  5. The selected VI should begin running.
Block Diagram
*Note: selecting anything other than a VI will cause an error because this functionality was not implemented in this example.
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Comments
PointOnePa
Member
Member
on
