Example Code
Acquire Waveforms and Resample them using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview
This example shows how to acquire waveforms in one loop, while reading those same waveforms and resampling them for display in a different loop.
2. Description
Using a producer-consumer architecture. The example shows a producer loop that generates (or acquires) waveforms and sends them to the consumer loop by using a Queue. In the consumer loop, the program resamples the waveforms according to the selected decimate rate to later show them in a chart.
3. Requirements
  • NI LabVIEW Professional Development System 2012 or compatible.
4. Steps to Implement or Execute Code
  1. Download and Run the VI.
  2. Select a decimation rate.
  3. Observe how the waveform appearance changes as you change its sampling rate.
  4. Press the stop button when done.
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Stephen B
