Example Code
Acquire Data on Mouse Event Using LabVIEW SignalExpress
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows you how to use LabVIEW SignalExpress to execute code based on a user event (e.g. mouse event).
 Description
 This example uses a simple LabVIEW VI to capture a mouse-click, and calls that VI from a LabVIEW SignalExpress project.In many data logging applications, it is nice to be able to have data acquired and logged based on user input. LabVIEW SignalExpress provides configureable logging conditions based on hardware triggers, software triggers, and date/time, but does not include a built-in way to acquire based on user input.
Requirements
  • LabVIEW 2012 (or compatible)
  • Signal Express 3.0 (or compatible)
  1. Open Mouse Event Project.lvproj to inspect the LabVIEW code used to capture the mouse event.
  2. Open Acquire Input on User Mouse Click_LVSE.seproj in LabVIEW SignalExpress
  3. Run the LabVIEW SignalExpress project. As saved, simulated Gaussian white noise will display on the waveform graph and a LED will turn on when the user presses or holds the left mouse buton.
VI Block Diagram
