Example Code
Acquire Data, Build Array, Find Maximum
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This VI use Simulated signal to demonstrate how to display data on the Waveform Chart and display all collected data on the Waveform Graph after completion.
Description: This example demonstrates a continuous acquistion that plots the data as it is acquired. It also builds an array of values that is used to find the maximum of the data channel.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Look at the result when stopped.
Additional Information or References:
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
