Example Code
Abort Execution Button Display Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI can prevent users from aborting a VI, using the Abort Execution button, instead of using a stop button
Description
There are a few less-known but helpful VI properties. One of which is the ShowAbortButton property. This way you can prevent VI users from aborting a VI instead of using a stop button. Using the TB.ShowAbortButton Property Node, which indicates whether to display the  Abort Execution button on the toolbar, while the VI runs, the VI can prevent users from aborting a VI using the Abort Execution button on the front panel.
Requirements
LabVIEW 2012 (or compatible)
     1. Run the VI
  1. Toggle the Show abort button
  2. See the display of the Abort Execution button on the toolbar ,while the VI runs
**This document has been updated to meet the current required format for the NI Code Exchange. **
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
