This piece of code represents the simplest method for controlling a brushless DC (BLDC) motor, 6-phase (also called trapezoidal) control. The algorithm uses feedback from hall sensors to dictate which FETs or IGBTs should be energized in the motor control bridge. The following diagram shows the hardware setup that accompanies this code.
The Compact RIO system reads the hall sensors from phases A, B and C and actuates a single high-side FET and a single low-side FET to make the motor spin either clockwise or counter-clockwise. Actuating the 7th FET with a PWM signal provides speed control by setting an effective bus level voltage. The code generates a 9-bit PWM signal (a magnitude of 0-511), resulting in a carrier frequency of just over 78kHz.
The following pictures show the code itself. The top loop in the code generates the FET signals based on the hall sensor input and the commanded bus voltage. The bottom loop generates the PWM for the bus-level FET.
The following picture show the hardware used to test this control algorithm (a custom-made motor drive bridge and a Maxon brushless DC motor).
More compliated control algorithms can be found at the following links:
sinusoidal control - https://forums.ni.com/t5/Example-Code/Look-up-Table-for-Sinusoidal-V-f-Control-of-a-Brushless-DC-Mot...
field-oriented control - https://forums.ni.com/t5/Example-Code/Field-Oriented-Controller-FOC-Space-Vector-Controller-for-a/ta...
Description-Separate-2
Ben,
I'm so interested in this project, that I wanna make one myself. Would you please send me more details about the motor drive bridge(circuit diagram,the data of every electronic component or the PCB). My e-mail address is coleviva@yahoo.com.cn.
Thank you for your time.
Sincerely,
Cole
I am interested to do it this project my self can u send me related papers to my mail id : venkat007ice@gmail.com
I nweed Related circuit connection details..
Thank you
could you please send me this program's JPGs? my e-mail : blue_dus46@hotmail.com
Hello Ben, I am interest in the BLDC control VI you shared, and could you send me detail information about 6-FET circuit which can be applied to this control method.
Look forward to your reply.
Thanks very much
Best Regards
I'm new here. This seems to be an old thread. All the jpgs are not showing. Could anyone share the information (or send to yfc500@gmail.com)? Thanks in advance.
