Overview
This example demonstrates how to acquire a finite amount of data (waveform) using the DAQ device's internal clock.
聽Description
The rate should be AT LEAST twice as fast as the maximum frequency component of the signal being acquired
Requirements
- LabVIEW 2012 (or compatible)
- Select the physical channel to correspond to where your signal is input on the聽聽
聽聽聽聽 DAQ device.
2.聽 Enter the minimum and maximum voltages.
VI Block Diagram
