Overview
Four run method- balancing
step 1: normal run
Step 2: RUNNING 0 (AT 0 DEGREE) - WITH TRIAL WEGHT
Step 3: RUNNING 1 (AT 120 DEGREE) - WITH TRIAL WEGHT
Step 4: RUNNING 2 (AT 240 DEGREE) - WITH TRIAL WEGHT
Step 5: READY TO CALCULATION
Step 6: CLICK ON DELIVERY POSITION TO CALCULATION
Describe
Four run method balancing - without phase.
Has really operations / practical test. High reliability.
Typical disadvantages: the number startup of the motor = 4 times
I sent to you the demo version. Who needs to use the full version, please contact: rslogic5000@gmail.com
(Run software, copy YOUR PC NAME, Send it for me)
Software request
This software is running with "LabVIEW Run-Time Engine 2015 - (32-bit)
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
