Example Code
3D Surface Graph Cursor in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This code allows the user to manipulate the position of a cursor on a 3D Graph.
Uses the 3D Surface VI to plot a simple surface from Z Matrix then Property Node CWCursor3D for setting X,Y and Z position of the cursor.
Description:
Plots a Simple Surface from Z Matrix using 3D Surface then specifies a collection of 3D object and sets X,Y and Z position of the cursor using Invoke nodes.
Requirements
LabVIEW 2012 (or compatible)
  1.  Run VI
  2. Adjust the X, Y and Z positions of the cursor, as desired
Dan King
