Overview
The purpose of this application is to show how using simple 3-d drawing functions you can create a cube which has different textures on each face.
Description
When you run the project and main application you will be presented with the finest of cubes which have dice faces textured to its surfaces. By pressing left, right, up or down you can navigate the faces of the cube. If you do not have a very quick GPU I would recommend changing the refresh rate of the drawing.
Requirements
VI Block Diagram
