Example Code
2D array control containing 1x1 colorbox
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI presents a custom control of a 2D array control containing a 1x1 size colorbox as its element.
Description
This control cannot be built in the LabVIEW editor because the minimum size bounds of the colorbox are normally 5x5. This custom control was created by LabVIEW R&D at customer request to facilitate drawing graph data arbitrarily. It is saved in LV 8.0 and should work in all versions of LabVIEW from there forward.
Requirements
  • LabVIEW 2012 (or compatible)
Run the VI and check the colorful array.
VI Block Diagram
Matt
NI Community Team
Comments
flarn2006
Member
Member
on
I'm really curious about the tools that were used to make this. Not that there aren't public tools that can do the same thing.
