Example Code
2D ANOVA with AB interaction Shown
Products and Environment
    Software
  • LabVIEW
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Description
When creating a VI using the example in the help for the 2D ANOVA VI, the example doesn't show how to use the VI in order to have an AB interaction. Instead, the data given in the help document will show the AB interaction of zero (the third row of the Info output array will be zero). The documentation doesn't make it clear how to structure a program in order to show an AB Interaction using the 2D ANOVA VI, so the following example was made to demonstrate how to use this functionality.
Zofia
NI Technical Support Engineer
