Example Code
2306 Power Supply GUI
Products and Environment
    Hardware
  • Modular Instrumentation
Code and Documents
Overview
    A power supply gui used to control the Keithley 2306
Description
    The 2306_GUI.vi is the top level vi. It is an event driven power supply. Change control:Hopefully all the vis and typedefs are here now. If there are any still missing let me know.thanks
Requirements
    Software
        LabVIEW 2012(or compatible)
        NI-VISA
    Hardware
        Keithley 2306
Comments
BetaCommunityCo
Member
Member
on
missing typedef
typedef and subvi's missing so no use at all
BetaCommunityCo
Member
Member
on
missing typedef
For output two "Select multiple for VDC #2" typedef I was using a typedef from my 2304a power supply and did not include it in the zip file. I should have used the same typedef for output one "Select multiple for VDC #1". I have updated the zip file and the gui. According to my vi hiearchy all the vis and typedefs should be there now. If you still have issues let me know.
