Overview
The example Demonstrates how to achieve 2-edge analog separation on a card when the counters are not available, or the signal is not TTL
Description:
Attached is code to achieve 2-edge analog separation on a card when counters are not available, or the signal is not TTL. Please note that the code require the first signal in the scan list to reach the analog level. Originally the second signal expected was a digital signal, which is why the control is labeled digital level.
Steps to implement or execute code
To implement this example:
This assumes that the analog signal is the first channel in the scan list, and the analog level is reached before the digital pulse comes.
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input Module
