Overview
This VI shows how to create and display first order and second order systems
Steps to implement or execute code
- Select the initial guesses, upper and lower limits for input values.
- Press Run
Block Diagram Steps:
- Input initial data, including limits and guesses
- Select which type of system you are replicating
- Create a Transfer Function
- Estimate the Transfer Function
- Simulate the model
- Draw the model as an equation, calculate L and C values from known R, display simulated response
Requirements
Software
LabVIEW 2012 or compatible
Control, Design, and Simulation Module 2012
Advance Signal Processing Toolkit 2012
Hardware
Stephanie L
National Instruments UK and Ireland
