Per scaricare il software NI, compresi i prodotti illustrati di seguito, visitare il sito ni.com/downloads.
Overview
This examples converts 1D binary arrays of customizable dimensions to its numeric representation.
Description
This example takes 1D arrays filled with ones and ceros and converts them to boolean arrays so they can be converted to their numeric representation.
Requirements
Modify the binary array to have the number of bits needed.
Manually fill the array.
Run the VI.
Main VI Block Diagram
Il codice di esempio scaricato dall'Example Code Exchange nella NI Community è concesso in licenza con la licenza MIT.
The FOR loop isn't needed. LabVIEW will do the Equals on the array with a scaler (comparing each element to the scaler).
Actually you are right, I totally missed that. Thanks for the feedback.
