Enhanced Icon Editor
[Bug] Set Icon Method
I have the above problem where I set an Icon of a size less then 32x32 (e.g. the banner for a class) then I use the invoke node to set the image data and the icon gets stretched to 32x32!!
Same thing happens for a VI method as well etc...
Is there a known workaround for this bug?
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
(6,581 Views)
What about making sure you have white padding pixels (not empty) below your banner?
For instance, if your banner is 8 pixel in height, draw a 32 x 24 (32-8=24) white filled rectangle below and see if this help.
PJM
(5,010 Views)
Sweet! Thanks Phillipe - that works
(IMO I still think its a bug and it should auto pad).
PS - How do I kudos around these parts???
(5,010 Views)
