Dynamic Signal Acquisition
Ni-DSA soft front panel does not work. It says "DSP personality loading", then freezes up.
NI PCI-4551 card is installed in the PC with NI-DSA v1.2. Labview 7.1 is also installed on the system. Until a couple of weeks ago, this problem never occured, and the system, other than windows (and corporate IT services) updates, nothing has changed on the system. The 4551 card checks out perfectly fine in MAX, and labview runs fine, but when DSA functions are used (including the DSA soft front panel program v1.2) the application using them hangs.
(6,571 Views)
Hi jcory,
What version of Windows do you have and what is the latest update you recieved?
Is there another PC that we could try the board in?  That would isolate the problem to either software or hardware.
This problem occurs with our examples also?
Sincerely,
Jason Daming
http://www.ni.com/support
(6,556 Views)
