Dynamic Signal Acquisition
Convert DAQ data into text
i want to convert the data that DAQ card receives into a format and feed it to some other simulation software. Can i do it. This should happen in real time. Say i m controlling a simulated robot arm through a real actuator. The actuator signal is passed from the DAQ card in some format as XML or text tot the simulation software. i would appreciate any suggestion or comments.
(7,124 Views)
You can use the waveform write to spreadsheet VIs in LabVIEW 6.1 as an easily programmed solution. There are also XML export VIs at: Use the XML VIs and functions located on the Functions»Advanced»Data Manipulation»XML palette to manipulate LabVIEW data in XML format.
Try these two approaches to see if they meet your requirements.
Preston Johnson
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(7,124 Views)
Hey everyone,
I am using DAQ in my research and collected some data with 50K sample rate and 7110 samples per second.
I am struggling in plotting the data with time.Please help.
Thanks.
I have attched the data I got .
(6,377 Views)
