06-30-2011 11:34 AM
07-01-2011 11:57 AM
Hi 4BoysDad,
Are you wanting to create an array of booleans in LabVIEW?
If so, you can place an array constant down, then place a boolean constant inside the empty array. This will turn it into an array of boolean data type. Then you can stretch the array out to add/remove the number of elements in the array (or use the up/down index arrows).
If you are trying to do this in something other than LabVIEW, let me know.
Also, for future reference your post will get more action if you post it in the correct subforum. This forum is for our DSA hardware, posting in the LabVIEW forum will result in faster answers.
07-01-2011 12:01 PM
Micah;
I have the array created
Now what I want to do is coninuously monitor this 8 switch 1D array (Boolean array) for changes i.e. any changes in the switch positions. I also would like to clear these switches on Stop.
Any suggestions?
Steve
07-06-2011 06:21 PM
Hi 4BoysDad,
I have a suggestion for the "clear switches on Stop". Create a local variable of the boolean indicator and insert a select as shown in the image below:
This seems to be a LabVIEW question, and as Micah mentioned it would be better if you posted your request in the LabVIEW forum. You would get faster replies.
Best Regards,
Jignesh P
07-07-2011 07:54 AM
thank you
