Dynamic Signal Acquisition
9401 timeout when using c api
Hello everybody,
I want to measure a frequency using the c api.
So I took the C example "DigFreq-LowFreq1Ctr.c" and ran it.
The interesing lines are:
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateCIFreqChan(taskHandle,"Dev1/ctr0","",1.192093,10000000.000000,DAQmx_Val_Hz,DAQmx_Val_Rising,DAQmx_Val_LowFreq1Ctr,0.001,4,""));
DAQmxErrChk (DAQmxStartTask(taskHandle));
DAQmxErrChk (DAQmxReadCounterScalarF64(taskHandle,10.0,&data[0],0));
I always get a timeout when trying to acquire the frequency value:
-200474. Specified operation did not complete, because the specified timeout expired.
I'm using a NI 9401 on slot 4 of a cDAQ-9174 (4 slot USB compact DAQ).
The example to count edges works fine for me so I'm wondering what I'm doing wrong.
Do I have to route a clock source to the counter first or did I forget something else here?
Thank you in advance.
King regards,
Fred
(6,096 Views)
Hi Fred,
please have a look at this Knowledge Base:
http://digital.ni.com/public.nsf/allkb/4E017925BDF2DC2D862572E6007C9594
Any input frequency below 100Hz yields error -200474, so you have to delete this error programmatically.
The introduced approach in LabVIEW can also be implemented in C.
Best regards
Christian
Christian
CLA, CTA, CLED
(6,072 Views)
