Driver Development Kit (DDK)
Setting Power-Up States for PFI/DIO on MSeries Boards
Hi --
I have a custom DDK-based driver that controls M-Series boards. I need to set the power-up states for some of the digital bits. I see that it is possible to do this via DaqMX, but that is not an option for me. Does anyone have some sample code or EEProm addresses that would help me accomplish this task in my driver?
thanks,
spg
scott gillespie
applied brain, inc.
Message 1 of 13
(10,300 Views)
Can any National Instruments folks comment on this?
thanks,
--spg
scott gillespie
applied brain, inc.
Message 2 of 13
(10,260 Views)
Hi Scott-
Do you mean that you'd like to apply the existing powerup states to the lines when your PC powers up, or that you would like a method to store new powerup states info into the the device EEPROM through the driver you're developing?
Tom W
Message 3 of 13
(10,258 Views)
Hi Tom --
Yes, I would like a method to store new powerup states info into the the device EEPROM through the driver I'm developing?
--spg
scott gillespie
applied brain, inc.
Message 4 of 13
(10,256 Views)
Hi Tom --
Yes, I would like a method to store new powerup states info into the the device EEPROM through the driver I'm developing.
--spg
scott gillespie
applied brain, inc.
Message 5 of 13
(10,252 Views)
Hi Scott-
One more question as I continue to investigate- which M Series boards does your driver support or will you plan to support this feature for?  Your assumption that they are identical is most likely valid, but I want to make sure there aren't any subtle differences to take into account.
Thanks-
Tom W
Message 6 of 13
(10,249 Views)
6251 and 6221, for now.
--spg
scott gillespie
applied brain, inc.
Message 7 of 13
(10,247 Views)
Actually, PCI-6221 (running on PowerPC macs) and PCIe-6251 (on Intel-based macs with PCI Express bus). Although I assume that the bus type doesn't matter in regard to the question at hand.
--spg
scott gillespie
applied brain, inc.
Message 8 of 13
(10,245 Views)
Hi Tom --
Any progress on this issue?
thanks, I appreciate the help.
--spg
scott gillespie
applied brain, inc.
Message 9 of 13
(10,196 Views)
Tom W. --
From an earlier post, you mentioned you were investigating this matter. Are you still?
--spg
scott gillespie
applied brain, inc.
Message 10 of 13
(10,147 Views)
