Driver Development Kit (DDK)
Reading/Writing to EEPROM & CalDac's
i am using eCos (Embedded Configurable Operation System) running on a simple intel base computer
 and want to read the calibration constt from EEPROM for NI PCI-6071E card.
but this code always return "myvalue=255". which is not the required value. can any body help me..
cyg_uint8 thisbit;
cyg_uint16 writevalue;
int myindex;
cyg_uint8 myvalue = 0;
writevalue=0x0BFC;//reading the NI-DAQ Board Code
//p_PCI_DIO96->io_address  is the Base Add 1.
// 0x4 - chip select - enable EEPROM communciation
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,0x00);
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,0x04);
for (myindex = 15; myindex >= 0; myindex--)
thisbit = ((writevalue >> myindex) & 0x01) * 0x02;
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,(0x04 + thisbit)); // set data bit
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,(0x04 + thisbit + 0x1)); // set data bit and clock
// read back PROMOUT (D7-D0) 8-bit result.
for (myindex = 7; myindex >= 0; myindex--)
// read bit
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,0x04); // set clock low
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,(0x04 + 0x1)); // set clock high
HAL_READ_UINT8(p_PCI_DIO96->io_address+0x01,thisbit); // read data bit
thisbit &= 0x1;
myvalue |= thisbit << myindex;
HAL_WRITE_UINT8(p_PCI_DIO96->io_address + 0x0D,0x00); // set rom low
printf("my Value = %d\n", myvalue);
printf("Execution completed");
(8,202 Views)
Hi arshad-
In order to read the NI-DAQ board code you should be looking at EEPROM offset 511; this means (by my calculation) that your writevalue should actually be 0x0BFF.  Are you able to read values from other locations successfully?
Thanks-
Tom W
(8,179 Views)
yes the address will be 0x0BFF.
i tried it with this address but same result .
infact i get 255 from all registers. mean same result from different address.
(8,170 Views)
Hi arshad-
I suspect that (despite the E Series RLP manual recommendation to write twice to each EEPROM access operation) your application is executing too quickly to allow the EEPROM to settle and respond correctly to your commands.  I would suggest that you instead add a short software delay between EEPROM access operations to lengthen the space between operations.  If your development system does not include a sleep() function you could just spin an empty loop for a msec or so to allow time for the operations to complete.
Thanks-
Message Edited by Tom W [DE] on 05-24-2007 10:10 AM
Tom W
(8,162 Views)
