Driver Development Kit (DDK)
Problem with AT-MIO-16
How can I install the AT-MIO-16-L-25 under windows 2000? I tryed Ni-Daq 6.1 but it crash during the card selection and the new Ni-Daq versions don't propose to install the AT-MIO-16-L-25.
Thanks to reply me.
(9,003 Views)
Please submit your questions in the Measurement Hardware -> Multifunction DAQ section of the discussion forum. That section will address NI-DAQ related questions.
The Measurement Hardware DDK does not support legacy MIO cards. RLP support for legacy MIO hardware (AT-MIO-...) can be found on the NI web site.
Christian L
Systems Engineer
NICS, National Instruments
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(9,002 Views)
The AT-MIO-16L-25 is an older card and is only supported under NI-DAQ 6.1 and earlier. You might try to uninstall and reinstall NI-DAQ 6.1. Unfortunately, NI-DAQ 6.1 is only supported under Windows 95/NT 4.0 and this is why you are running into problems. The link below describes the process for installing non plug-and-play hardware. I would recommend upgrading to a newer data acquisition device.
Installation Procedure for Non-Plug and Play Compatable DAQ Boards
http://www.ni.com/support/install/nonpnp/nonpnp_daq.htm
(9,002 Views)
I tryed that solution but windows 2000 crash before the card selection... I can't access to the card list.
(9,003 Views)
