Driver Development Kit (DDK)
PCI 6220 linux
I am working on an application specific driver to for the PCI 6220 under linux.
I have the DDK and visa lib installed.  I am trying to get the aiex2 example working.
I get a clean compile, but the string argument to acqireBoard() appears to be wrong, or the installation is wrong.
The example come with the code as follows:
bus = acquireBoard( "PXI4::1::INSTR");
lspci -v for my system with the PCI 6220 installed is as follows:
0000:00:08.0 Class ff00: National Instruments: Unknown device 70b0
        Flags: bus master, medium devsel, latency 32, IRQ 11
        Memory at d2800000 (32-bit, non-prefetchable) [size=4K]
        Memory at d2802000 (32-bit, non-prefetchable) [size=4K]
I did find the document that tries to explain the string format, but nothing I've tried seems to work.
I coded the following and no combination worked:
    for( int i=0; i<16; i++ )
       for( int j=0; j<24; j++ )
          char str[80];
          sprintf( str, "PXI%d::%d::INSTR", i, j );
          bus = acquireBoard( str );
          if( bus != NULL )
            printf( "found board at i=%d j=%d\n", i, j );
            break;
Suggestions?
Message 1 of 13
(11,260 Views)
Could you give us a few extra pieces of information.
1)  What Linux distro are you running?
2)  You mentioned that you have NI-VISA installed.  Which version do you have?
3)  Are you using the NI-VISA OS Interface?  (there are a couple different ones out there)
-Alan A.
Message 2 of 13
(11,244 Views)
Suse 9.3 kernel 2.6.11.4-20a
NI-VISA 3.4
yes  as found in the nimseries.zip
as downloaded from links on:
http://digital.ni.com/express.nsf/bycode/exyv4w?opendocument&lang=en&node=seminar_US
Message 3 of 13
(11,239 Views)
Ok, so you probably just need to add a like to visaconf.ini which is located here: usr/local/vxipnp/linux/NIvisa
Before the 'Aliases' stuff, add this line:  ShowRegisteredDevOnly = 0
This should fix your problem.
FYI - the string passed to the acquireBoard function is a VISA PXI resource string.  The format is:
PXI<bus_number>::<device_number>::INSTR
NI-VISA allows more complicated strings that allow you to specify the function number and other PCI attributes.  The PCI bus, device and function numbers allow you to form a unique id for any device on the system.
The lspci output format for the location of the PCI device is:
<bus>:<slot>.<func>
where slot is the the device number.  The format might change slightly between distros.  For your device, my guess is that the string is PXI0::8::INSTR.
-Alan A.
Message 4 of 13
(11,232 Views)
Unfortunately, I still get the same results.
Stepping into acquireBoard I get the return status on viOpen
of -1073807343
Does this give any hints?
Message 5 of 13
(11,224 Views)
Could you run visaconf and see if your device is found by that utility?
-Alan A.
Message 6 of 13
(11,207 Views)
visaconf only shows serial ports
Not the PCI 6220.
Message 7 of 13
(11,208 Views)
Try unzipping this attachment and putting the .inf file in this directory:  /usr/local/natinst/nipal/etc/inf
Alan A.
Message Edited by Alan [DE] on 02-13-2006 11:03 AM
Message 8 of 13
(11,203 Views)
That did it.  Thanks!
Message 9 of 13
(11,189 Views)
Now I'm not getting reasonable data from the ddk examples programs aiex1.cpp and aiex2.cpp.   I tie channel 0 to ground or a voltage and the readings don't follow.
Has anyone else got these examples to work?
Message 10 of 13
(11,153 Views)
