Do More with Your NI USB-TC01
Reply
Highlighted
Introducing the NI USB-TC01 with NI InstantDAQ Technology
National Instruments new USB-TC01 is the easiest way to make temperature measurements with your PC. Simply plug-in the device to a USB port and without any prior driver installation, built-in software for graphing and logging data is automatically loaded. View a 2-minute video demo at ni.com/usb-thermocouple.
The new USB-TCO1 features the following:
  • NI InstantDAQ technology to instantly take measurements with your PC, no driver install required
  • Standard miniplug for easy thermocouple connection
  • Compatible with J, K,R, S,T,N and B thermocouples
  • Available with included J-Type exposed-tip thermocouple or thermocouple probe
  • Additional downloadable free applications for generating alarms, logging to a spreadsheet, and scheduling logging times
  • NI-DAQmx support for LabVIEW graphical programming and software customization
Chris Delvizis
(5,212 Views)
Re: Introducing the NI USB-TC01 with NI InstantDAQ Technology
want to use NI-DAQmx to log data from two or more of these as a multi-channel device.  Can it be done?
If not, is there a USB version of multi-channel device that would work with NI-DAQmx?
(1,163 Views)
Hey laserjunkie-
No, unfortunately you can not have a multi-device task in NI-DAQmx with the USB-TC01.  One good bed, since you need USB, would be to use something like the cDAQ-9171 and a thermocouple module like the NI 9213.  You can find such a bundle here.
Tom W
(1,163 Views)
Reply
