Distributed Control & Automation Framework (DCAF)
Standard Engine Configuration Class not found
So far faced multiple issues with DCAF installation but finally got the example working. Created a very simple DCAF project using the template and added a random number generator module(actually generates a sine wave). However, I got the following error. Did I miss something when creating the project or edited configuration file? Any help will be appreciated. Module and main added.
(6,038 Views)
Never mind. I did not include the required class into Includes.vi.
(6,029 Views)
What installation issues have you run into? Also just curious, what getting started material are you using? If there are any things that could be improved with that process let us know and we can add them as issues in GitHub.
(6,015 Views)
There were multiple issues when got DCAF from VIPM and opened the Temp Controller example. Same sort of errors in this post http://forums.ni.com/t5/Distributed-Control-Automation/Installation-and-Getting-Started-with-DCAF/gp.... Reinstalling resolved it but had to do it couple of times.I haven't tracked or taken any screen shot of the errors I got which I should have. Planning to install DCAF in a new machine and will post if I encounter same issues.
(6,003 Views)
