Distributed Control & Automation Framework (DCAF)
Problem Loading DCAF Editor Config
I have installed the DCAF framework from VIPM but when I try to open the example configuration in the DCAF editor I get an error saying the system diagnostic configuration class not found.  I have included a screenshot of the error and a screenshot of the DCAF I have installed from VIPM.  Any ideas on how to fix this?
(5,038 Views)
The plugins for the example are not listed in the default search paths.  In the DCAF Editor, go to Tools>>Edit Plugin Search Paths and add the DCAF Examples directory to the list if it is not already there.
<LabVIEW>\examples\DCAF Examples
If you are using LV 2015, the path should look like this:
C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\DCAF Examples
If this does not solve the issue, please send a screenshot of the search paths dialog.
Cheers,
Matt Pollock
(4,903 Views)
