Distributed Control & Automation Framework (DCAF)
How to solve this mistake ?
once run cRIO main.vi ,make this mistake
(5,157 Views)
Exit labview appear
(5,147 Views)
Accepted by topic author lk410305
Hi lk410305, it looks like the problem is in the shared variable module, and the path you are using for your variables might be wrong. Did you change the name of the channels, or the ip of the target?
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(5,124 Views)
Thanks. I changed the name of channel is : ni.var.io://192.168.2.1/模块1/RTD0 . Everything is OK.So just miss "模块1"
(5,103 Views)
