Distributed Control & Automation Framework (DCAF)
Building DCAF PC Engine GUI into executable
Oh gotcha. Yeah I was able to build the example project. Let me dig into mine a bit more, but if I can't figure it out, I may take you up on the offer.
Message 11 of 13
(3,092 Views)
Hi all, was there any resolution on this one? Getting the same error code but for the systems diagnostics module.
Message 12 of 13
(2,734 Views)
Hi, I have a similar problem with Labview 2017 trying to build a simple test application. The real problem I have is trying to build an application which includes DCAF on Windows only and this returns a "dll not bound" error  relating to RT FIFO vis.
I've tried to uninstall and re-install DCAF but can't seem to do that either, uninstalling DCAF in VIPM gives "Error Source: (bad package file specified) " and of course I can't install when it's installed.
Any advice would be greatly appreciated.
Mike
Message 13 of 13
(2,448 Views)
