Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
GPIB and K1944A
I'm actually using a GPIB and a voltmeter ( KETHELEY). I generate a signal (sine for instance) thanks to a frequency generator and I want to acquire it with the voltmeter and send measures through the GPIB to plot them on a graph.
I want to give you an extract of the code where I have troubles to understand :
short k1944a_device (void)  {   return bd;  }
short k1944a_ready (void)
    short i;
    do { ibwait (bd, 0x4800); ibrsp (bd, &sp); i++; }
    while ((!(sp & 16))&&(i<10));
    if (i==10)
         MessagePopup ("", "Le volmËtre ne rÈpond plus");
         return 0;
    return 1;
short k1944a_ecrire (char *texte)
    short ok;
    ibwrt (bd, texte,(long)strlen(texte));
    ok=k1944a_ready ();
    if (ok==0) return 0;
    return 1;
 When I run the code and click and the button acquire the programm freezes and I can read in RUN TIME window the following error:
NON-FATAL RUN-TIME ERROR : "K1944lab.c",line38,col5,trhead id 0x0000234: Function ibwrt(iberr == 6(0x6))
Moreover, when I try to run the code I get this message : NON-FATAL RUN-TIME ERROR..... Local 'i' was referenced before being initialized. Should I absolutely initialize it?
0 Compliments
Message 1 sur 3
5 648 Visites
somebody here?...
0 Compliments
Message 2 sur 3
5 637 Visites
Thanks for posting on NI Forum.
You can find at this link a possible solution to your problem.
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
0 Compliments
Message 3 sur 3
5 633 Visites
