cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Introducir columnas en subarray
Buenas, estoy trabajando con un archivo con 3 columnas y 700 filas y al final descompongo con un subarray para tomar cada columna por separado, pero en el index cuando pongo por ejemplo el elemento 0 me lo lee como una fila y necesito cambiarlo para que lo lea como una columna. Agradecería ayuda.
0 kudos
Mensaje 1 de 2
1.405 Vistas
Hi Goku,
please ask English questions in this forum…
@GokuJubilao wrote:
Good, I am working with a file with 3 columns and 700 rows and in the end I decompose with a subarray to take each column separately, but in the index when I put for example element 0 it reads it to me as a row and I need to change it so that it read as a column. I would appreciate help.
When you get rows instead of columns then you did something wrong.
Unfortunately you forgot to attach your VI!
Indexing arrays is very basic LabVIEW stuff: did you note those "Trinaing resources" in the header of the LabVIEW board?
(Most probably you have to use a different input of IndexArray to get a column instead of a row. Or transpose the array before using an autoindexing FOR loop!)
0 kudos
Mensaje 2 de 2
1.371 Vistas
