cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
How to find the L293B componet on the library?
Multisim library does not contain the component L293B.
How can I add this component to the library? In the library there is something similar?
0 kudos
Mensaje 1 de 2
4.409 Vistas
In Multisim you can create custom components using the Component Wizard (Tools>>Component Wizard). However, if you want to create a simulatable component a SPICE model is needed; SPICE models are created by the components manufacturers. I did a research but couldn't locate a SPICE model for the L293B component (note that you can also create the component just for schematic capture and layout).
Anyway, here is a tutorial on how to create custom components:
Creating a Custom Component in NI Multisim
Also, take a look of the following forum post:
Where Can I Find Components And Footprints Not Included In The Circuit Design Suite Databases?
Let us know if you have further questions.
Fernando D.
0 kudos
Mensaje 2 de 2
4.389 Vistas
