Discovering and Imaging the Device
roboRIO continuous flashing status led (unrecoverable error)
Hi! Greetings from Team 5705,
We're having the same trouble trying to flash our roboRIO, we've already tried everything described on the device's manual, as well as in this forum.
Does someone have a solution for this?? Our roboRIO has definetely died?
The device turns on, but it doesn't appears on the Imaging tool, the tool displays a "<No RoboRIO targets found>" sign with a yellow warning triangle as shown below.
And also we've tried using several laptops with different Windows versions, but unfortunately it's the same thing.
We'll be so thankful if someone provides us a way to solve this.
Thank you very much in advance.
(3,140 Views)
When you boot up the roboRIO, what do you see on the various LEDs?
(3,089 Views)
Same for us.  When we boot up after reimaging the SD Card, we get green power light, continuously flashing orange status light, and no other lights.  it also shows same no device found on robot image tool
(3,049 Views)
We have also tried different SD cards and different computers
(3,046 Views)
Try using the guide here: https://docs.wpilib.org/en/stable/docs/software/roborio-info/roborio2-imaging.html
If using the third-party burning option listed there doesn't work, please create a new thread here.  Jumping into another thread tends to add more confusion than clarity to either issue 😃
(3,038 Views)
