Discovering and Imaging the Device
No roboRio targets found
To prepare the robot we're following a step by step guide made by first in Michigan. When we imaged the SD the first time everything went fine and we were abled to image the rio using the imaging tool. When we started working on the radio we were having problems connecting to it. We went back to see if there was an error with the rio. When going back to the imaging tool we were unable to connect to the rio even though the power light was green and the status light was off. We tried typing variations of the team number but still nothing was showing up. We also tried to resetting the rio and reimaging the SD but still nothing. We're thinking maybe we put in the wrong team number, if so could we reset?
Message 1 of 8
(4,440 Views)
Hi Aiafirst, Thanks for posting on the forums. I'm Matthew with NI.
When you re-image the SD card, it will be a completely fresh image (with no team number set).
Which imaging software are you using (Raspberry Pi or BalenaEtcher)? (https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html)
With a freshly imaged SD card, and the roboRIO connected via USB, are you able to ping 172.22.11.2 and get a response?
Message 2 of 8
(4,424 Views)
To image the SD we used BalenaEtcher.
Trying to ping it with a re-imaged the SD card and the roboRIO connected via USB the response is
Pinging 172.22.11.2 with 32 bytes of data:.
Reply from TTL expired in transit.
Request timed out.
Ping statistics for 172.22.11.2:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Message 3 of 8
(4,403 Views)
Ok, so no ping indicates so your computer is failing to establish communications with the roboRIO (for any any of a number of reasons).
Just to be absolutely certain that the device is not functioning, can you try imaging an SD card with the Raspbery Pi imager and see if the device will connect with that SD card inserted?
Message 4 of 8
(4,399 Views)
Reimaged with the Raspbery Pi imager and still nothing showing up
Message 5 of 8
(4,384 Views)
I've sent an email to the address listed on your profile on next steps.
Message 6 of 8
(4,375 Views)
Hello, it sounds like our team is having the same exact problem and we can't find the answer. Is there anyway you can relay the solution if you guys found it? You can reply here or send it to our email topsailroboticsteam@gmail.com. Thank you!
Message 7 of 8
(4,278 Views)
@Topsail_Robotics_Team , please post a new thread for your issue. "me too" posts cause confusion for which teams have tried what specific steps.
Also: if your trying to connect via ethernet, (if you're not) try connecting to the roboRIO via USB as the networking modes change throughout use and may or may not work directly anymore.
Message 8 of 8
(4,274 Views)
