Digital Multimeters (DMMs) and Precision DC Sources
problems with sequential AC volts measurement
I'am use a NI-4060 to measure some AC volts (the range is 127V to 220V with 60Hz). If I take the measures sequentially without put a Delay between the measures, the NI-4060 measures AC volts that does not exist, It seems that the NI-4060 have an buffer to integrate the measures, and doesn't empty it to do other AC measurement. The question is, exist one way to realize sequentially measurements without put a delay between it?
(6,621 Views)
Hey Gilson,
You should not have any problem measuring AC Voltage with a DMM on one channel. Are you switching the DMM between two different channels? If that is the case, you might need a delay for settling time while the board adjusts to the new voltage. How fast are you sampling with the 4060 board? What software are you using to take these samples?
Robert
(6,621 Views)
