Digital Multimeters (DMMs) and Precision DC Sources
How to move y scale position in waveform graph?
I would like to ask how to move the y-scale position in waveform graph? Take a ocilloscope as example. Y scale postion can adjust up or down. Do you have this vi example? Thanks.
(7,298 Views)
Are you asking how to programmatically change the maximum and minimum values of the Y-axis? This would be done very simply by using a property node for the graph and selecting the Y Scale>Range>Maximum (or Minimum) property.
(7,287 Views)
Thank you for your information. I have done it.:)
(7,281 Views)
