Digital Multimeters (DMMs) and Precision DC Sources
Difference between Reference and Start in Triggering ?
Hi
Can anyone explain What is the difference between the Reference and Start when Triggering ? and when should you use them?
Any commets will be very much appreciated..
Many Thanks in Advance
Mohamad
(7,769 Views)
Start trigger is the trigger signal used for post-triggered acquisition. The hardware starts the A/D conversions after the trigger is received.
Reference trigger is the trigger signal used for pre-triggered acquisition. The hardware starts acquiring data before the trigger signal is received.
For more information about this, please read the Tips and Techniques in DAQ triggering with NI-DAQmx
If you are using a DSA card, also read Trigger Condisions for Analog Start and Reference Triggers in the Same Channel for DSA Cards
(7,754 Views)
Many Thanks Kabul...
Mohamad
(7,752 Views)
