Digital I/O
serial command syntax
Dear all,
I'm trying to comunicate with a device via a serial port. For this sake, I'm using the "Advanced Serial Write and Read.vi" from the examples library. I put the right prameters but I still can't figure out the right syntax for the srting filed to be written on the serial port. I always get a timeout error message.
Could you please give me an exemple of a command (string) to send to the serial port.
Please find in the attachement the protocol data sheet.
Thanks for your help.
(3,822 Views)
Hi JB,
Unfortunately, I can't give an example command for this device, each device has it's own commands, an example of a common command is *IDN? which used by many instruments, but I don't know if your instruments will recognize it. I think the best is to contact the provider of the instruments.
ClémentG
(3,794 Views)
Thanks, I've already find a solution. You have to right commands either in hexa or ascii code and not to mix both as indicated in the data sheet.
regards
(3,791 Views)
