Digital I/O
install NI-DAQmx driver in Linux device
Hi, I have installed NI-DAQmx driver and also nidaqmx python library in my linux machine.
This error show up when I execute below code:
File "/usr/local/lib/python3.8/dist-packages/nidaqmx/_lib.py", line 213, in _import_lib
raise DaqNotFoundError(
nidaqmx._lib.DaqNotFoundError: Could not find an installation of NI-DAQmx. Please ensure that NI-DAQmx is installed on this machine or contact National Instruments for support.
Is there anyone knows how to fix it?
(4,139 Views)
I have similar issue, unfortunately did not find a fix yet.
my test code is:
import nidaqmx
system = nidaqmx.system.System.local()
len(system.devices)
for device in system.devices:
    print(device.name)
And the result for "python testdaq.py" is:
Traceback (most recent call last):
  File "/home/testdaq/testnidaqmx.py", line 3, in <module>
    len(system.devices)
  File "/usr/local/lib/python3.10/dist-packages/nidaqmx/system/_collections/device_collection.py", line 72, in __len__
    return len(self.device_names)
  File "/usr/local/lib/python3.10/dist-packages/nidaqmx/system/_collections/device_collection.py", line 90, in device_names
    cfunc = lib_importer.windll.DAQmxGetSysDevNames
  File "/usr/local/lib/python3.10/dist-packages/nidaqmx/_lib.py", line 160, in windll
    self._import_lib()
  File "/usr/local/lib/python3.10/dist-packages/nidaqmx/_lib.py", line 205, in _import_lib
(3,965 Views)
Small progress happened, got rid of the error message. Did the following:
#installs the nidaqmx from apt
apt install ni-daqmx
#reboot has to be done
reboot
But the errror kind of  persists.
I edited a bit my testprogram:
import nidaqmx
print("There is %d devices available " % (len(system.devices)))
    print(device.name)
So "python testdaq.py" provides following output:
There is 0 devices available
while lsusb gives:
Bus 001 Device 003: ID 3923:71df National Instruments Corp. NI USB-6525
I guess the issue may be that the nidaqmx for linux does not support my beautiful usb6525 device :(, or does anyone have different knowledge?
(3,959 Views)
(3,949 Views)
All USB-based DAQmx devices (with the exception of USB cDAQ) are not supported on Linux Desktop and Linux RT.
https://tmesystems.net/
(3,942 Views)
