Digital I/O
input/output code for PCI-6503
Hello
      I use PCI-6503 with win98 and VB6. I set port0 and port1 for input by dip switch.
And set port2 for output by LED. So I want to know code for read input from port0 and port1.
and code for write output at port2.
      Ex.     text1.text = data from bit1 of port0
                text2.text = data from bit1 of port0
                if text1.text = some value then
                      LED at bit1 of port2 ON
      It more better if you can make example program.
Thank you for your support
(3,516 Views)
Hi jum,
On the Windows 98 platform, the most recent driver version supported by the PCI-6503 is NI-DAQ 7.1.  NI-DAQ 7.1 includes the API for both Traditional NI-DAQ and NI-DAQmx.
The Traditional NI-DAQ API is what will be used for your application because NI-DAQmx 7.1 does not have support for Visual Basic 6.0.  After installing the drivers, you can find information about the different functions available in Traditional NI-DAQ by navigating to Start» Programs» National Instruments» NI-DAQ» Traditional NI-DAQ Function Reference
Example programs should also be included with the installation, and they would be located in the NI-DAQ 7.1 directory (the default should be C:\Program Files\National Instruments\NI-DAQ\Examples\VBasic).
Andrew W
(3,504 Views)
