Digital I/O
how can I transform the digital waveform into analog waveform, and put the digital waveform display in a analog waveform chart
Any suggestions would be greatly appreciated.
kairong12345
(5,505 Views)
Have you looked at the Waveform palette? You would have seen Digital to Analog.vi. That's assuming you are using LabVIEW.
(5,500 Views)
Hi Dennis Knutson
   Thanks for your answer,Yes.I have,but it doesn't work like what I want . the program generates three digital waveforms ,which I want to transform into analog waveforms,But The analog waveforms which have been  processed by Digital to Analog.vi,  are not the same as it is displayed in digital diagram,
The software I installed is Labview 8.2, What is the problem I encounter,What I shoud do to acquire the three analog waveforms
The digital waveforms
But the transported waveforms are as following
The transformed waveform
(5,489 Views)
If I recall, you have to do one signal at a time.
(5,465 Views)
I see,It's very inconvenient ,I have to try this method,since I haven't found other ways.
Thanks for your suggestion
(5,454 Views)
