05-23-2007 04:34 AM
05-25-2007 03:14 AM
05-25-2007 05:20 AM
On the other hand, it was not trivial to me, to which amount should I set the output buffer. Especially in the case of my PCIe card, which has little onboard memory.
Ideal solution to me would be if you could rewrite that sample to PCIe6536/7 comment and upload it. I'm just talking about this AO example because I feel thet understanding that could take me closer to my solution. Thanks for the support.
05-30-2007 10:10 AM
05-30-2007 12:30 PM
That was whatI did before to com to these problem.
Anyway, with more experiencing I managed to do the job, and it seems working with 25MHz In and Out 🙂
For example which is non trivial:
DAQmxCfgPipelinedSampClkTiming sets the buffer size according to the help: If sampleMode is DAQmx_Val_ContSamps, NI-DAQmx uses this value to determine the buffer size.
That's true for the input task.
But I should set it again with the DAQmxCfgOutputBuffer command in case of the output otherwise it stops with -200621 error.
