Digital I/O
executable program
Hello
 I have a problem and need a help.
The executable program that I create does not work on another pc,
which does not have Laview installed.
Why not work?
I need to install some functionality?
(4,391 Views)
You need to install at the very least, the LabVIEW run-time engine.
Did you create an installer or just copy the exe? It's always a good idea to create an installer. I don't know why you posted this question to the Digital I/O board but if you are using an NI DAQ board, you will also have to include the driver (i.e. DAQmx), configuration from MAX, etc.
(4,388 Views)
Thanks for the county. I will try. My application and to send messages by RS232. And as I am new to LabVIEW, I still have some difficulties
(4,384 Views)
Then besides the LabVIEW runtime, you will need the VISA runtime. I would also recomend installing MAX.
(4,382 Views)
