Digital I/O
digital IO using daq legacy function in Visual C
Hello.
I'm trying to control stage by digital I/O through PCI 6503.
I wrote a Labview program using DAQmx sub VIs, but it's not working.
So I plan to use functions in DAQ legacy such as "DIG_PRT_CONFIG".
The reason what I'm doing is because I have a piece of C code from manufacturer, which is written in DAQ legacy environment.
BTW, firstly, I'm trying to read a port. I used the example code in "//National Instrument/NI-DAQ/example" folder.
The following is that code. (I slightly changed)
#include
"nidaqex.h"
* Main:
void
* Local Variable Declarations:
main(void)/*
i16 iStatus = 0;
i16 iRetVal = 0;
i16 iDevice = 2;
i16 iPort = 0;
i16 iMode = 0;
i16 iDir = 0;
i32 iPattern = 0;
i16 iIgnoreWarning = 0;
 /* Configure port as input, no handshaking. */
iStatus = DIG_Prt_Config(iDevice, iPort, iMode, iDir);
iRetVal = NIDAQErrorHandler(iStatus,
iStatus = DIG_In_Prt(iDevice, iPort, &iPattern);
"DIG_Prt_Config",iIgnoreWarning);"DIG_In_Prt",iIgnoreWarning);"test.txt", "w");" The digital pattern on port %d is (DECIMAL) %ld\n", iPort, iPattern);
FILE *fp;
fp=fopen(
fprintf(fp,
I used "i16 iDevice = 2;", because in MAX, PCI 6503 is assigned as Dev1, first one is another board("PCI 6110E") I'm using.
And, this code gives error code -10401. I know DAQ legacy is supporting PCI 6503, so I don't know why this error is occured.
18993i3F3623B960CA4803
Also, I used another VI program which detects board in DAQmx, DAQ legacy. In this program, all devices are well detected by DAQmx, but not in DAQ legacy.(samely, give error code -10401).
I'm attaching the LabView program in this post.
aa
Message 1 of 1
(4,064 Views)
